VNC no Mouse Cursor
PreviousPage 2 of 3Next
Hi matterantimatter:
A known bug that has been reported and ticket created for the cursor issue with NoVNC.  Some of my team members have been able to replicate the issue.
Thanks for sharing.
Hi All
I have the same problem, will this be resolved shortly
Hi @kryten
Thanks for letting us know.  I'll update the bug ticket to add your response.
Hi Daniel, thanks
Just to let you know regarding the missing mouse novnc issue:
  • Hardware surface pro 7
  • Window 11
  • Browser MS edge, I have flushed the cache and problem remains
  • I have tried other browsers firefox, brave and chrome
daniel.luck has reacted to this post.
daniel.luck
Hi @kryten
Thanks for providing the info.
We were also able to replicate the issue with different configurations.
Hi Daniel
When do you think this will be solved. I was reading on the novnc site that this happens if "local cursor" is not selected. When looking at the advanced settings the version of Antsle has this setting greyed out.
Hi @kryten
Sorry we don't have an ETA for this.
Hey Daniel
This has been bugging me, so have been playing around and I think I found a work-around
Basically I took the address from the noVNC screen and pasted it into browser
http://xxxx.local:6903/vnc.html?host=xxxx.local&port=6903&autoconnect=true and changed it to:
http://trek.local:6903/vnc.html?host=trek.local&port=6903&cursor=true
the ubuntu antlet came up and showed the cursor, when I went back to antman and used the console button, the screen opened and the cursor was there working.. Not each time I have used it the cursor was there.
When i tried a different antlet the cursor was not there.. I tried the same process on this antlet it worked the same way...
Anyway if others want to play let me see if you see the same as me...
matterantimatter and daniel.luck have reacted to this post.
matterantimatterdaniel.luck
Hi @kryten
Thanks so much for the potential workaround.
I'll let our team know and I'll be doing some testing with as well.
Hi @kryten
I've shared with our team.
I've have successful test using Win10StdGUI template.  I'll be testing with Win11StdGUI template next.
Thanks for your contribution!
