Hi @kryten
No, I don't you are able to remove the Win11 template if you have antlets based on this template (due to zfs dependencies).
We had a script that I had tried posting in the forums but there was an issue with getting the syntax properly formatted.
What I meant is that you can delete other templates that you aren't using (such as CentOS 7 which can take some space) if you see them in the Templates section.
Yes, you can use this command to copy back the original.
cp image.qcow2_backup image.qcow2
Hope that helps.
Hi @kryten
Hope that helps.
