Am I required to have a plan to upgrade?
Quote from brandonwolf on January 14, 2022, 7:25 pmSaw that 3.4.3 was out, attempted to run antman-upgrade and I'm receiving a message that I am not subscribed to upgrade and to purchase a plan...that's true. I'm just running a homelab on an older Antsle One and neither need nor want to pay $29 a month for it.
Previous upgrades were assumedly part of the purchase, but is this now a new requirement?
Quote from daniel.luck on January 20, 2022, 3:37 pmHi @brandonwolf
If you are running on antsle hardware, you can use the Home Lab and use edgeLinux/antMan without plan. Upgrading to plan gives you access to more features and support.
You can use these commands to try upgrading antMan:
service anthilld restart
service anthilld status
upgrade-antmanIf this still doesn't work, you can perform manual upgrade with commands below:
Try downloading antMan from your anthill.antsle.com account in the Downloads page.
Copy the file to your antsle using scp or an sftp client like Filezilla (https://docs.antsle.com/system/secure-ftp-sftp-access)
On the antsle's command line, extract the file
tar -xzf antman-X.X.X-x86_64.tar.gzOr for Nanos
tar -xzf antman-X.X.X-aarch64.tar.gzCD into the new directory
cd antman-x.x.x-x86_64and run the installer
./install
Hi @brandonwolf
upgrade-antman
./install
Quote from brandonwolf on April 11, 2022, 6:27 amSorry for the delay in response, just wanted to say the manual steps you described worked great! Thanks Daniel
For anyone else reading this, you can use wget instead of sftp.
Log into anthill.antsle.com
Click on "Downloads" and find the latest antman version, copy the link
in the terminal: wget <paste url to antman file here>
Continue with the tar/cd/install as per above.
Quote from daniel.luck on April 11, 2022, 1:41 pmHi @brandonwolf
Yes, I forgot to mention you can absolutely use the wget command, and that's what I'm using on my antsle's to download packages such as latest antMan as needed.
Thanks for the great tip!
Hi @brandonwolf
Quote from brandonwolf on August 28, 2022, 3:53 pmHi, just wanted to say thank you for this -- it did work!
Quote from daniel.luck on August 29, 2022, 5:29 pmHi @brandonwolf
Thanks for the update.
Glad to see that this worked for you.Thank you,
Hi @brandonwolf
Quote from anaglyph on February 1, 2023, 1:32 pmSystem says It can't download my license after the upgrade. I do have two licenses, and anthill shows it connected to this antsle. How do I download one of my licenses back into the upgraded system?
Quote from daniel.luck on February 1, 2023, 5:57 pmHi @anaglyph
Are you using edgeLinux 0.12.0 or earlier? If so, follow the steps below to upgrade your antMan.
You can check in antMan > Settings or on the command line with
antsleOS-versionIf so, you will need to download the antMan bundle from your anthill.antsle.com account in the Downloads page - antMan 3.4.4 for x86_64
Copy the file to your antsle using scp or an sftp client like Filezilla (https://docs.antsle.com/system/secure-ftp-sftp-access)Or download it directly to your antsle with 'wget'. Right click the Download link and copy the link address. Then SSH to the antsles command line and run the 'wget' command and paste the link e.g:
wget https://s3.wasabisys.com/wasabi--cloud-6a2aa848-8fea-4d97-b476-2e5ef9db7c18/antman-updates/antman-3.4.4-x86_64.tar.gzYour link may be different than this example so be sure and copy the link from antHill.
tar -xzf antman-X.X.X-x86_64.tar.gzCD into the new directory
./installThanks you,
Hi @anaglyph
./install
Thanks you,
Quote from bbergman on February 6, 2023, 8:58 amThe download link for the x86 tar file gives this error (see attached screenshot):
This page contains the following errors:
error on line 1 at column 1: Encoding errorBelow is a rendering of the page up to the first error.
Uploaded files:Quote from daniel.luck on February 6, 2023, 5:56 pmHi @bbergman
Thanks for letting us know about the error above.
I am getting the same error when I try downloading directly from antHill Downloads page.
I'll reach out to our Developers and let them know about this error.
Hi @bbergman
