Docker is a service running in edgeLinux - so I get that you can spin up a docker container e.g. hello world.
Now what if I want to do something more persistent e.g. run a mongo database service?
- I will need to modify the edgeLinux setup so that it starts etc whenever the antsle boots - so what is the guidance on what can be modified and keep the edgeLinux supported e.g. startup scripts?
- how do you expose the edgeLinux docker container running mongo to an antlet VM so that they can use it?
Alternative is to run docker in an antlet - and make that the database service in this example
- do you have to install Docker inside the antlet (this is explained well in this post)?
- or is there a way to configure the antlet so the underlying edgeLinux docker service can be presented for use in the VM?
