Amber LED: activity indicator?
Gyorgy
What does the amber light indicate on the front of Antsle device (right next to power)?
I never noticed it before but it appears to be solid, sometimes blinking. I assumed it was activity but I'd like to check in case it indicates some sort of a problem. Antman UI does not indicate any problems.
Also what is the acceptable CPU operational temperature for Antsle?  We have it between 80-85C
Thanks!
210 postsedited
Regarding the CPU temp, we had a hot summer here in Oklahoma so I was monitoring it.
If you connect to the IPMI console ( Step 4 here https://docs.antsle.com/setup/ ), you can see the temperature sensors:
Server Health -> Sensor Readings
It shows the current temp and the range.
For my Antsle  XD Pro, the CPU shows a threshold of 96 C and I've never seen it more than 60 C.
Gyorgy
I do not have access to IPMI (no dedicated network connection), I have been getting temperature with this CLI tool: https://github.com/cjbassi/gotop
Thanks!
I've been told (but haven't tried it myself) that you can plug a network cable into the IPMI port and then plug the other end into a laptop and access the IPMI console.
