I'm stuck with the upgrade.
After trying upgrade-edgelinux script, it gets stuck on the emerge
How do I move forward?
* Last emerge --sync was 148d 15h 27m 13s ago.
* IMPORTANT: 3 config files in '/etc/portage' need updating.
* See the CONFIGURATION FILES and CONFIGURATION FILES UPDATE TOOLS
* sections of the emerge man page to learn how to update config files.
!!! Problems have been detected with your world file
!!! Please run emaint --check world
!!! Ebuilds for the following packages are either all
!!! masked or don't exist:
app-admin/eclean-kernel
!!! All ebuilds that could satisfy ">=dev-util/cmocka-1.1.1[abi_x86_64(-)]" have been masked.
!!! One of the following masked packages is required to complete your request:
- dev-util/cmocka-1.1.5::gentoo (masked by: EAPI 7)
- dev-util/cmocka-1.1.3::gentoo (masked by: EAPI 7)
- dev-util/cmocka-1.1.3 (masked by: EAPI 7)
The current version of portage supports EAPI '6'. You must upgrade to a
newer version of portage before EAPI masked packages can be installed.
(dependency required by "net-fs/samba-4.8.6-r2::gentoo" [binary])
(dependency required by "net-fs/cifs-utils-6.7::gentoo" [binary])
(dependency required by "@selected" [set])
(dependency required by "@world" [argument])
For more information, see the MASKED PACKAGES section in the emerge
man page or refer to the Gentoo Handbook.
* Failed to emerge @world, aborting.
Error while upgrading edgeLinux
