Hi all - I have antsle one XD with 4 cores. Things were going fine, then suddenly yesterday it dies on me. There was no power outage nor any other disruption of power. Just does not turn on. No lights, nothing. I have the OEM equipment. Had it for less than 2 years. Anyone with similar experience? Antsle customer service has been less than helpful.
Power failure
Is the power supply's green light on? If not, you may need a new power supply. You can get one here if you need it.
I had a similar issue where it just lost power after about 16 or 17 months of use. At first it would power back on for a minute before powering off, then not at all. I didn't feel like throwing any more good money after bad, so I wound up buying a used server from servermonkey, after which I decided to see if the antsle fix would be easy. I took it apart and found one of the components had melted off. After posting on reddit, someone alerted me to the C2000 clock bug which I think fits the description of at least my issue.
This is what's left of my $3347 antsle (the rest will be recycled) after 17-18 months.
@jiyeongkim I had the same issue last year. If the attached image is like your power supply, then yes you probably need a new one. It's a cheap power supply and burns out often. It's just a laptop power brick. I'm glad to see that Antsle quit using them on their new models.
Thank you everyone for the response. I ended up contacting [email protected]. I had to send my antsle XD over to get it inspected. It wasn't the power brick after all but rather a bad motherboard. Keeping my fingers crossed that this time it lasts longer than 2 years.
How did you manage to get a response from [email protected]?
Quote from ericl on November 4, 2020, 7:32 am
Hi Eric:
Just send an e-mail to [email protected] and ticket should generated.
Here's link to power supply for antsle One D and XD:
https://shop.antsle.com/product/power-supply-antsle-one/
