Need help with the setup of my Antsle purchased in Apr, 2017
iamsingularity
Hi,
I had purchased an Antsle in April 2017.
But for some personal reasons, I never really had a chance to activate and use it.
I finally had an opportunity to activate it earlier this month. But I was unable to activate my antsle on anthill with the serial number and the default password (printed on the delivery note).
Can someone please help me with this issue?
And I am also a little confused with the following note in your online documentation:
'If you purchased your antsle before Dec 14th, 2017 you will need to run upgrade-antman at the antsle's command line in order to activate your antsle in anthill'.
How do I access the command line in my anstle and run the command 'upgrade-antman'?
doug.knowles
17 postsedited
Plug it into the network, power it up, look at the attached devices for the network and use that IP address to ssh in as [email protected] and the password in your paperwork. Then run the command upgrade-antman.
iamsingularity
Appreciate your prompt response.
I tried to SSH into anstle as per your instructions, but I couldn't sign into it.
I have attached a screenshot of the error in my SSH client for your reference.
I am not sure why the password isn't working. This instance of antsle was never really set up before. So, that rules out the possibility of password change.
