NANO - System Information (Versions)
HaleyStaff
Hi @doug007,
Thanks for reaching out! You can run the below command to be on the current version:
upgrade-antman 3.0.0c
Stephan
@haley What is the release schedule for updates to antMan?
SD
HaleyStaff
Hey @shop, there is a new official upgrade coming soon. Though I don't know the official release date, I know we have an unofficial version I'm allowed to give out that addresses large backup uploads and general stability improvements. To get it, run:
upgrade-antman 2.2.0g
HaleyStaff
@shop, Thanks for checking. The 3x versions are for eL2, including Nanos. 2x versions are for Gentoo, so you should stay on the 3x versions.
