Nano and 8GB Raspberry Pi 4?
Quote from Marc Baum on June 26, 2020, 9:43 amHey @jefkelle!
The edgeLinux version moved out of beta - the official image is now available via this link: https://s3.wasabisys.com/wasabi--cloud-6a2aa848-8fea-4d97-b476-2e5ef9db7c18/edgeLinux/edgelinux-2.1.0-aarch64.zip
Hey @jefkelle!
Quote from Nike on October 20, 2020, 1:12 amHi All,
Got a question, I swapping my Pi 4 4GB for 8GB. Also got a SD card of 400GB.
What is the best way of formatting the SD card for the Nano?
Just format the whole card as FAT32 and copy the files over from edgelinux-2.1.0-aarch64.img?
Or format it in exFat and use dd command to copy the edgelinux-2.1.0-aarch64.img to the card?
I am using a Mac.
Naik
Hi All,
I am using a Mac.
Naik
Quote from Marc Baum on October 20, 2020, 1:32 amHi @nike!
You don't need to format your SD-Card. Instead, you'll need to flash the image using a tool like etcher or Rufus. Here's the link to etcher, just select the edgeLinux .img as source and your sd-card as destination: https://www.balena.io/etcher/
When using dd, you also don't need to format the card. Just make sure you specify the entire card as output, not just one partition. (e.g. on your Mac: /dev/disk2 instead of disk2
s1or something)Please don't try to mount the IMG file and copy the files over manually, as this will not clone the partition map and your Nano will not boot.
Best,
Marc
Hi @nike!
When using dd, you also don't need to format the card. Just make sure you specify the entire card as output, not just one partition. (e.g. on your Mac: /dev/disk2 instead of disk2s1 or something)
Best,
Marc
Quote from Nike on October 20, 2020, 9:41 pmThank Marc,
I got almost working.
After the boot I could only access the Nano via the ip number:3000 after getting a new serial key myantsle.local started working.
However some services are not starting by default after a reboot;
ntpd - dead
virtlogd - dead
zfs-zed - dead
I only can manual start ntpd and virtlogd.
zfs-zed is not starting at all I am getting the following error message
"SA-1: Error Redirecting to /bin/systemctl start zfs-zed.service Failed to start zfs-zed.service: Unit is not loaded properly: Invalid argument. See system logs and 'systemctl status zfs-zed.service' for details."
Naik
Thank Marc,
ntpd - dead
virtlogd - dead
zfs-zed - dead
Naik
Quote from reachcybersecurelabs on January 3, 2021, 9:31 amJust invested in a rasberry pi for the sake of testing Antsle onsite. We have downloaded the LinuxedgeOS from the site and have also created the SD card and booted successfully! After successful boot, we observed a very long and painful hours of loading once we have loggedin via HTTP. See attachment.
Can you please advise as we are new to the product and want to start testing and setting up as soon as...
Uploaded files:Quote from daniel.luck on January 4, 2021, 4:09 pmHi Naik:
These services should have been fixed in updated release of edgeLinux 2.1.0.
Please let us know.
Thank.
Hi Naik:
Please let us know.
Thank.
Quote from daniel.luck on January 4, 2021, 4:11 pmHi Reach Cyber Secure Labs:
Are you able to SSH in the nano?
If so, please run the following commands and let us know the output.
systemctl status antman
ss -tpln | grep 3000
Please let us know.
Please let us know.
Quote from lancem on January 5, 2021, 12:50 pmHow can we upgrade our nanos to 2.1.0?
If I do upgrade-edgelinux it checks for version 0.12.0.
Or is it a re-install to go from 2.0.0 to 2.1.0?
Quote from daniel.luck on January 5, 2021, 5:54 pmHi LanceM:
Yes, that's the only way that I know to burn new SD Card for your nano.
You can find the download here: http://anthill.antsle.com/#/downloads
Here's the direct link also: https://s3.wasabisys.com/wasabi--cloud-6a2aa848-8fea-4d97-b476-2e5ef9db7c18/edgeLinux/edgelinux-2.1.0-aarch64.zip
Please let us know how it goes.
Hi LanceM:
