creating antlets running ubuntu 16.04:
when I create an LXC version and network bridge and expose it to the local network, the ports forwarding from the router to the local IP in this case ports 80 and 443 works fine.
when I create a KVM version and network bridge and expose it to the local network, the ports forwarding from the router to the local IP in this case ports 25, 80, 143, 443, 465, 587, and 993 works fine(as expected) on the local network, but are not accessible through the router using the same port forwarding set up as the LXC version.
I have verified that the KVM version has the default gateway set to the correct router address.
I am pulling my hair out can anyone help?
thanks
