[Help] - ZPool not mounting on reboot
barduino
Hi Folks,
I've installed a USB drive and created a zpool on it following the documentation here. All good no issues.
However, when I reboot my Antsle it does not boot up.
I have to unplug the USB drive and then manually import de zpool again.
What is the proper way to have zpool automatically mount?
Appreciate your help
Cheers
barduino
Replying to my self here...
Figured it out, this is a BIOS problem...
Every time you add a USB device to the Antsle, the board BIOS will make it the first priority in the boot sequence.
Very annoying...
