Hello, I am having problems with connecting the wifi. I have gotten it active, but it is not connected.
I followed the guide on this page: https://docs.antsle.com/networking/wifi-on-the-antsle-nano, and everything seemed to work there.
But when I type ifconfig, the wlan0 block, while it does exist (showing that it is active), has no inet, netmask, or broadcast (meaning it must not be enabled)
I also tried commands from the following page: https://askubuntu.com/questions/398581/is-there-a-terminal-command-to-verify-if-wifi-is-enabled
And this command:
nmcli general status
shows:
STATE CONNECTIVITY WIFI-HW WIFI WWAN-HW WWAN
connected (local only) limited enabled enabled enabled enabled
The command:
nmcli radio wifi
shows:
enabled
but, the command:
nmcli connection show --active
shows:
virbr0 bd201f3d-d784-4d90-9bff-ec3ed9b2d6e9 bridge virbr0
virbr1 571acab0-ba2b-4d20-9084-3834072266b1 bridge virbr1
that is, it only includes virbr0 and virbr1 in the list, and excludes wlan0.
I also find that has soon as I unplug an ethernet cable, I loose connection to my antsle nano, but if the wifi is working, since it connected to my router, and my pc that I am using to connect to the antsle nano is also connected to the same router, shouldn't I still be able to access it? So I really think that eventhough my wifi on my antsle nano seems to be enabled, that it is not active.
