I've setup Elasticsearc and Kibana on an Antlet on my AntsleOne. I'd like to setup Metricbeat on the AntsleOne to push data into the ElasticKibana VM. However, pretty sure the IPtables setup on the AntsleOne is block the AntsleOne from communiting with the Antlet on port 9200. External access for Port Forwards to the Antlet work fine.
Does anyone have a suggestion on how to tweak the iptable config on the AntsleOne allowing it to communicate directly with an Antlet on port 9200/tcp ?
