My BR2 port seems to not be functioning, recently I was having issues where I was getting the following
#service anthilld start
- Bringing up interface br2
- ERROR: interface br2 does not exist
- Ensure that you have loaded the correct kernel module for your harware
- Error: net.br2 failed to start
- Brining up interface eno3
- config_eno3 not specified; defaulting to DHCP
- dhcp ...
- Running dhcp ...
eno3: waiting for carrier
timed out
dhcpd exited
- ERROR: net.eno3 failed to start
- ERROR: cannot start anhilld as net.br2 would not start
After running the upgrade-antman script again, it solved the issue but br2 is disabled. Re-enabling it causes the issue where it can't detect and won't start andhilld.
