Issue with br2
jmcginty
See screenshot attached
I re-enabled br2 in the network section of the interfaces, afterwards I was unable to access the antsle web interface due to anthilld getting shutdown. Trying to re-start the anthilld service showed the following errors.
I believe this might be a hardware issue, in the past I had tickets relating to br2 loosing its IP address.
Re-running the upgrade-antman script seemed to disable br2 and solve the issue with access, just means that I am unable to use br2 for anything.
Hello jmcginty,
Thank you for reporting this error. Please know and be assured that your report has been sent to the development team, and they will fix it as soon as possible.
