Any way to remove edge experts popup on login to antsle?
Solved2 replies
louie432843
If I click "check our plans" or "remind me later" the result is the same: The popup is there every time I log into antman.
Johannes DietzelAnswerPicked by the antsle Team
You can turn the edgeXperts sales page off in antMan by going to the `[Gear icon on the top right corner] > System settings`, then uncheck `Show edgeXperts status` and `Save preferences`
