Antlet Connection to USB Phone
Petey488
Hey All,
Can I get pointed in the right direction for how to connect a Android phone via USB to an antlet?  I currently am doing some mobile application analysis/mobile pentesting and want to be able to make some mobile devices be accessible to my Kali Linux Antlet.
Regards,
Petey488
Hi Petey488:
You can follow directions for USB Passthrough to enable the device on your antlet below.
https://docs.antsle.com/system/usb-drives#usb-pass-through
Petey488
Thank you, but I am confused on how this can work in the long run.  The nature of working on phones is that they reboot all the time, everyt ime they reboot they can no longer connect to my KVM as the Device ID changes leading me to have to reboot the entire Antlet.  Additionally, the Antlet retains the old configuration and I need to go through the console to edit the appropriate configuration files.  Is there a better way to do this or a possible fix for this behavior?
Thanks!
Hi Petey488:
Yes, this is a known behavior and editing the XML is the correct way to fix to get USB Passthrough working again.
Hi @cinthya98
Sorry to hear about that.
Thanks for the feedback, and I'll let our team know.
