curl - Could not zfs clone for antlet ...
Quote from tliddle30 on June 9, 2018, 6:51 pmI'm trying to use curl to create an antlet and I'm receiving the following error. I did read a previous post on the error that ran a few commands to ensure the antlet was removed, however, no matter what I change the
dname
too I get the same error.Any help that can be provided would be appreciated.
Error
{"success":false,"message":"1 Could not zfs clone for antlet testserver1"}
I've tried the following commands
Without optional
zpool-name
curl -X POST -H 'Authorization: Token ey.....' --header 'Content-Type: application/json' --header 'Accept: application/octet-stream' -d '{"dname": "testserver1","template": "Ubuntu16.04 - KVM","ram": 1,"cpu": 1,"antlet-num": 15,"compression": "inhert"}' 'http://domain.local/api/antlets'
With optional
zpool-name
curl -X POST -H 'Authorization: Token ey...' --header 'Content-Type: application/json' --header 'Accept: application/octet-stream' -d '{"dname": "testserver1","template": "Ubuntu16.04 - KVM","ram": 1,"cpu": 1,"antlet-num": 15,"zpool-name": "antlets","compression": "inhert"}' 'http://domain.local/api/antlets'
I'm trying to use curl to create an antlet and I'm receiving the following error. I did read a previous post on the error that ran a few commands to ensure the antlet was removed, however, no matter what I change the dname
Error
Without optional zpool-name
With optional zpool-name
Quote from tliddle30 on June 15, 2018, 5:37 pmI wanted to provide an update on this. After some investigating, I was able to create the antlet successfully. There were a few things that I changed. First, the template name was incorrect. In the portal it is advertised as
Ubuntu16.04 - KVM
, however, after doing azfs list
when logged into a terminal session it was listed asUbuntu16.04
. Second I removed thezpool-name
and changed theram
to MiB (megabytes). Lastly, I changed thecompression
toon
.After that my antlet was created. The full command to run on a Linux machine is below. I hope this helps someone. I also recommend reading the article about
zfs
. It was a great reference for me. Click HereAs you test the API, clean up activities are necessary when things go wrong or error out. It was a great reference for me.
$ curl -X POST --header "Content-Type: application/json" --header "Accept: application/octet-stream" "http://domain.local/api/antlets" -d '{ "dname": "servertest1","template": "Ubuntu16.04","ram": 1024,"cpu": 1,"antlet-num": 16,"compression": "on"}'
I wanted to provide an update on this. After some investigating, I was able to create the antlet successfully. There were a few things that I changed. First, the template name was incorrect. In the portal it is advertised as Ubuntu16.04 - KVM
, however, after doing a zfs list
when logged into a terminal session it was listed as Ubuntu16.04
. Second I removed the zpool-name
and changed the ram
to MiB (megabytes). Lastly, I changed the compression
to on
After that my antlet was created. The full command to run on a Linux machine is below. I hope this helps someone. I also recommend reading the article about zfs
