Since there isn't much support in this forum or community activity, I've spent considerable time myself learning how to best use my Antsle and Docker. Since learning the basics of Docker and how to setup containers to run applications, I've come to the conclusion that in most cases on the Antsle, a container is the way to go vs a traditional VM (ie: Antlet). For service type servers (Webapps, DNS, Plex, LDAP, etc), it's simple enough to get everything up and running in Docker and not use an Antlet at all. Here's a good, quick example to install BitBucket on your Antsle using a container:
1) SSH into your Antsle server
#ssh [email protected]
2) Create a docker volume for BitBucket
#docker volume create --name bitbucketVolume
3) Install BitBucket
# docker run -v bitbucketVolume:/var/atlassian/application-data/bitbucket --name="bitbucket" -d -p 7990:7990 -p 7999:7999
atlassian/bitbucket-server
4) Open your new BitBucket instance in your web brower:
http://myanstle.antsle.us:7990
What once took me an entire evening on a Windows Server (ie: create Antlet, install Windows, patch, install Postgres, install BitBucket), now literally takes less than 3 minutes to be up and running.
My challenge now has been getting full SSL working with my Docker containers. I do have SSL working on my Antsle, however working with the NGINX reverse proxy to the Docker containers has been tricky. Anyway, hope this helps!
will, r3chris and 4 other users have reacted to this post.
willr3chrisWard Mundyklfrazierthe_threat_of_loveterryj72
