Actual capacity varies with software configuration. In the default setup, the two drives are mirrored, so you can only use the capacity of one of the drives, and the other one mirrors the data for safety.
Furthermore, compression is on by default which can increase the effective capacity, typically by factors 1.2 to 2.5, depending on the nature of data stored.
