How do we do it?
Thanks to our innovative cooling technology, dedicated server rooms or sound-proof cases are a thing of the past. With antsle, the case is the heat sink so there are no fans, no vent holes, no noise!
Depending on the antsle model and load you are running, the case can get warm. Especially our XD models with the Xeon-D CPUs pack a punch and while they can get hot under load, you still won't hear a sound from within.
